查看: 708|回复: 0
八代凯美瑞颠覆过去 换上新装再出发 改装过后更是惊艳
发表于 2020-9-26 16:48:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Eight generations of Camry overturned the past, put on new clothes and set out again. After refitting, it was even more amazing
广汽丰田恪守“通过汽车创造美好生活,服务和谐社会”的立业宗旨,全心全意地为顾客提供性能卓越、环保的汽车产品与细致周到的服务。
凯美瑞是广汽丰田旗下的一款车型,37年来,历代凯美瑞都持续领先,赢得全球2000万车主的信赖。
GAC Toyota adheres to the business tenet of "creating a better life through cars and serving a harmonious society", and wholeheartedly provides customers with excellent performance, environmental protection automobile products and meticulous and thoughtful services.
Camry is a model owned by GAC Toyota. Over the past 37 years, Camry has been leading the way and won the trust of 20 million car owners around the world.
Airbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! Once every 5-5 years, no fatigue problem! After strict testing equipment to test pressure, full pressure can be sold! Through high-pressure locking equipment, the outer layer of the leather bag is protected by anti-corrosion, rainproof, sand and dust resistant materials!
