查看: 752|回复: 0
高品质的豪华车丰田皇冠改装气动避震最强低趴风姿态
发表于 2020-9-24 16:45:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
High quality luxury car Toyota Crown refitted with the strongest aerodynamic shock absorber and low prone wind posture
Crown is a large and medium-sized car brand of Toyota group. Toyota Crown was launched in Japan on January 1, 1955. There are more than the 13th generation models. The domestic crown engines are 2.5L, 3.0L and 4.3L. The first two engines are V6 cylinder 24 valve design, and the 4.3L engine is V-type eight cylinder. Dual VVT-i intelligent timing variable system of inlet and outlet valves is configured.
The intake efficiency, fuel economy and power performance of the engine are greatly improved, and the horsepower is more powerful. In terms of chassis, it adopts four-wheel fully independent suspension, which is very comfortable.
汽车改装属于汽车后市场的一种产物,许多车型因为原厂的设计比较平庸,不能满足玩家的要求,因此就出现了改装行业的繁荣现象,气动避震悬挂的改装属于一种外观的姿态改装,以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣,一起来欣赏 丰田皇冠改装案例|气动避震底盘升降改装风格
Car refitting is a product of the automotive aftermarket. Many models can't meet the requirements of the players because of the mediocre design of the original factory. Therefore, the refitting of the pneumatic shock absorber suspension is a kind of appearance posture modification, which causes strong resonance with the good feeling of the players close to the ground, strong visual impact and unconventional state, Let's enjoy Toyota Crown modification case | pneumatic shock absorber chassis lifting modification style
上面说了4点好处,其实啊,大多数车友是为了更好的趴低……车子低了对我们来说才是美,才有范儿。还能够享受周围人们的注目,也是一件极其满足虚荣心的事情。这个减震器的叫法是学术名字,通俗的叫法避震器或者吸震器,这些叫法都是个人喜欢知道有这回事就好了。
减震器的工作原理主要用来抑制弹簧吸震后反弹时的震荡及来自路面的冲击。在经过不平路面时,虽然吸震弹簧可以过滤路面的震动,但弹簧自身还会有往复运动,而减震器就是用来抑制这种弹簧跳跃的。减震器的种类从产生阻尼材料的角度划分,减震器主要有液压和充气两种。
There are four advantages mentioned above. In fact, most of the riders want to lower themselves better The lower the car is, the better it is. It is also a matter of great vanity to be able to enjoy the attention of people around. The name of this shock absorber is an academic name. The popular name is shock absorber or shock absorber. I like to know about this.
The working principle of the shock absorber is mainly used to suppress the shock of spring rebound and the impact from the road. Although the shock absorption spring can filter the vibration of the road surface when passing through the uneven road surface, the spring itself will have reciprocating motion, and the shock absorber is used to restrain the spring jumping. The types of shock absorbers are divided from the angle of producing damping materials. There are mainly two kinds of shock absorbers: hydraulic and pneumatic.
