查看: 721|回复: 0
宝马E39气动升级完工AIRBFT气动套件氮气版静音泵鱼雷罐三段记忆
发表于 2020-9-24 15:32:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW E39 pneumatic upgrade completed airbft pneumatic kit nitrogen version silent pump torpedo tank three section memory
AIRBFT专用气囊:
Airbft special airbag:
Like airbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! Single fatigue times 3 million to 5 million times, normal use of 3-5 years no problem! All air bags are sold after full pressure test! The clamp part of the leather bag is compressed by high-pressure locking equipment, and the normal pressure test is at 200psi, explosion-proof! The outer layer of the leather bag is protected by anti-corrosion, rain, sand and dust resistant materials! Give you the safest protection!
