查看: 777|回复: 0
无折腾不青春 奥迪A3改装气动避震低趴案例
发表于 2020-9-24 15:21:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Case study of Audi A3 refitting pneumatic shock absorber
奥迪A3是奥迪出品的一款轿车产品,基于大众MQB平台研发,车身采用轻量化设计和铝制材料,动力上搭载1.4TFSI和1.8TFSI等多款发动机。
奥迪A3底盘前悬架为麦弗逊式,后桥为扭转、曲柄式结构带分开布置的弹簧和减振器,除了操纵性极佳外,后悬架布置的空间利用率也很高,因此载货面积在同级车中出类拔萃。所有A3系列车型,前后制动均为盘式,前制动带通风槽。
Audi A3 is a car product produced by Audi. It is developed based on the MQB platform of Volkswagen. Its body is made of lightweight design and aluminum material. It is equipped with 1.4tfsi and 1.8tfsi engines.
The front suspension of Audi A3 chassis is McPherson type, and the rear axle is of torsion and crank structure with separate springs and shock absorbers. In addition to excellent maneuverability, the space utilization rate of rear suspension layout is also very high, so the loading area is outstanding among the same class of vehicles. For all A3 series models, the front and rear brakes are disc type, and the front brake is equipped with ventilation groove.
奥迪A3改装气动避震悬挂是一种非常热门的改装方式,奥迪A3外观线条设计流畅,时尚动感,改装一个简单的外观姿态只能算是锦上添花,但是低姿态的改装绝对是一种魅力的升华,打造的低趴效果造成强烈的视觉冲击感!来欣赏这辆改装AIRBFT四轮独立悬挂的奥迪A3拥有怎么样的魅力!
Audi A3 refitting pneumatic shock absorber suspension is a very popular modification method, Audi A3 appearance line design is smooth, fashionable and dynamic, refitting a simple appearance posture can only be regarded as icing on the cake, but the low posture modification is absolutely a charm sublimation, the low lying effect creates a strong visual impact! Come and enjoy the charm of this modified airbft four wheel independent suspension Audi A3!
Pneumatic shock absorber is a more precise part. Different from the original shock absorber, there is an elastic rubber air bag on the pneumatic shock absorber. The working principle of the elastic rubber air bag is to fill the sealed pressure cylinder with inert gas or oil-gas mixture, so that the pressure in the chamber is several times or dozens of times higher than atmospheric pressure. The cross-sectional area of piston rod is smaller than that of piston And the resulting pressure difference to achieve the movement of the piston rod. Pneumatic shock absorbers are not suitable for driving on various complicated road conditions. Long term driving on bumpy roads will lead to chronic air leakage, unstable air pressure, temperature rise in the air tank, and eventually lose the accuracy of pneumatic adjustment.
