查看: 588|回复: 0
AIRBFT氮气时代来临 氮气版气动避震解决传统避震不舒适双向可调阻尼
发表于 2020-9-24 14:56:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The arrival of air dynamic shock proof in nitrogen age of airbft
The installation of pneumatic shock absorbers will link a control remote controller in the vehicle. Several gears can be set according to their own requirements, which can realize the rapid switching between various heights, so that the vehicle can "lie down" on the ground when parking, and can rise to the normal driving height when driving normally.
