查看: 427|回复: 0
AIRBFT G1-4堵头自带O型密封圈304不锈钢气动避震安装方便快捷
发表于 2020-9-23 13:22:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft G1-4 plug with O-ring 304 stainless steel pneumatic shock absorber installation is convenient and fast
The working principle of pneumatic shock absorber is to change the height of the vehicle by controlling the air pressure, which includes the tooth cutter damper, air pressure control system and electronic control system. In the car show or the car friends' party, we often see a lot of "lying down" cars on the ground. Many people who have not seen will think how to drive the car. Don't worry. One click to fix you.
