查看: 809|回复: 0
奥迪A4B9气动避震低趴改装姿态醉人
发表于 2020-9-22 13:50:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奥迪A4B9气动避震低趴改装姿态醉人
Audi a4b9 pneumatic shock absorber low prone refitting posture intoxicating
奥迪B9指的是bai奥迪A4L,意思是B级车第九代,du前面还有B8、B7、B6。
B级车,即中型车,或称作zhiLarge Family Car,轴距是2.7米至dao3.0米,车身长度4.8米至5.0米,排量在1.5升至2.5升。
Audi B9 refers to Bai Audi A4L, which means the ninth generation of B-class cars. There are B8, B7 and B6 in front of Du.
Class B vehicles, or medium-sized cars, or zhilarge family cars, have wheelbase of 2.7 meters to dao3.0 meters, body length of 4.8 meters to 5.0 meters, and displacement of 1.5 to 2.5 liters.
奥迪A4 B9气动避震低趴改装姿态醉人。奥迪A4B9的出现让很多爱改装的车友做不住了,帅气犀利的外观设计,不整一辆改改就安耐不住这个躁动的心。今天我们就来欣赏一下 改装分享的奥迪A4B9改装AIRBFT气动避震的案例介绍!
Audi A4 B9 pneumatic shock absorber low prone refitting posture intoxicating. The appearance of Audi a4b9 makes many car owners who love refitting unable to do it. The handsome and sharp appearance design can not bear this restless heart without changing the whole car. Today, let's enjoy the case of Audi a4b9 refitting airbft pneumatic shock absorber!
