查看: 905|回复: 0
玩的就是姿态 丰田卡罗拉改装气动避震玩转低姿态
发表于 2020-9-21 15:41:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Play is posture Toyota Corolla modified pneumatic shock absorbers play low attitude
卡罗拉(Corolla),曾用译名“花冠”,是丰田汽车的一个品牌。卡罗拉采用的是米其林轮胎215/45 R17轮胎、TRD Sportivo高性能减震器、TRD TF4 17寸运动型轮毂、强化离合器、高性能刹车片则保证其拥有比较理想的运动性能。
第一代卡罗拉于1966年发布,当时作为一款国民车推出,由于价格低廉,受到了当时消费者的热捧,到如今已经发展到了第11代,卡罗拉依然是全球最畅销的车型之一。
Corolla, once translated as corolla, is a brand of Toyota. Corolla uses Michelin tire 215 / 45 R17 tire, TRD Sportivo high-performance shock absorber, TRD tf4 17 inch sports wheel hub, reinforced clutch and high-performance brake pad, which ensure its relatively ideal sports performance.
The first generation of corolla was released in 1966, when it was launched as a national car. Due to its low price, it was warmly welcomed by consumers at that time. Up to now, it has developed to the 11th generation, and the Corolla is still one of the best-selling models in the world.
AIRBFT专用气囊:
Airbft special airbag:
