查看: 560|回复: 0
一发不可收拾的经典情怀,宝马E38低姿态气动避震改装
发表于 2020-9-21 15:05:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A classic feeling out of control, BMW E38 low attitude pneumatic shock absorber refitting
E38是什么车?按照辈分来算,是目前贩售的7系的爷爷辈。经典的理由是什么呢?就是担任电影《玩命快递》第一部里头,杰森·斯坦森饰演的男主角出场开的车,不过电影里头那部是不带“L”的短轴,且据说是宝马特意为电影打造的手动版E38,市场上显然是打着灯笼都找不到的……如果你对那部电影有印象,就一定会E38刮目相看。
What kind of car is E38? In terms of seniority, they are the grandfathers of the seven series currently on sale. What are the reasons for classics? It's the car that Jason stanson, the leading actor in the first movie of the movie "play for life express", drives the car. However, the short axis in the movie does not have an "L" and is said to be a manual version of E38 made by BMW specially for the film. Obviously, it can't be found in the market with lanterns If you have an impression of that film, you'll be impressed by E38.
