查看: 840|回复: 0
运动健将宝马X5气动避震改装案例
发表于 2020-9-19 16:29:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
运动健将宝马X5气动避震改装案例
Refitting of BMW X5 pneumatic shock absorber
减震器的工作原理主要用来抑制弹簧吸震后反弹时的震荡及来自路面的冲击。在经过不平路面时,虽然吸震弹簧可以过滤路面的震动,但弹簧自身还会有往复运动,而减震器就是用来抑制这种弹簧跳跃的。减震器的种类从产生阻尼材料的角度划分,减震器主要有液压和充气两种。
The working principle of the shock absorber is mainly used to suppress the shock of spring rebound and the impact from the road. Although the shock absorption spring can filter the vibration of the road surface when passing through the uneven road surface, the spring itself will have reciprocating motion, and the shock absorber is used to restrain the spring jumping. The types of shock absorbers are divided from the angle of producing damping materials. There are mainly two kinds of shock absorbers: hydraulic and pneumatic.
所谓改装车,按照我个人的理解,就是两个改装路线,性能和姿态。当然,有不少改装玩家对于性能和姿态都想兼顾,这样的想法是好的,但是却很难真正实现,以后我们专门找个机会讨论关于性能和姿态不可兼得的问题。今天我们来讨论的就是走姿态路线改装车的终极武器,气动避震。The so-called refitted vehicle, according to my personal understanding, is two refitting routes, performance and posture. Of course, there are many modified players who want to give consideration to both performance and posture. This is a good idea, but it is very difficult to really achieve it. In the future, we will take a special opportunity to discuss the issue of not having both performance and posture. Today we're going to talk about the ultimate weapon of the attitude line modified vehicle, pneumatic shock absorption.
AIRBFT专用气囊:
Airbft special airbag:
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc. Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful.
