查看: 749|回复: 0
宝马3系改装AIRBFT三段式记忆气动避震套件, 满足你的姿态低趴欲望
发表于 2020-9-19 15:56:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW 3 Series Modified airbft three-stage memory pneumatic shock absorber package to meet your desire for low posture
宝马3系是宝马集团新一代轿车产品,车身重量1465千克,直列4缸汽油发动机,车型尺寸为4.734米,1.811米,1.455米。
BMW 3系再次为同级轿车设立了新标准,其美学设计、工程学设计、高科技内涵,以及豪华舒适性和安全性等方面都达到了全新的境界。宝马3系价格定位也体现其高档运动轿车的市场定位,并反映其高档产品内涵。
BMW 3 series is a new generation car product of BMW Group, with body weight of 1465kg, in-line 4-cylinder gasoline engine, and model size of 4.734m, 1.811m and 1.455m.
BMW 3 Series once again set a new standard for the same class of cars. Its aesthetic design, engineering design, high-tech connotation, luxury comfort and safety have reached a new level. The price positioning of BMW 3 series also reflects the market positioning of its high-end sports car and the connotation of its high-end products.
汽车改装属于汽车后市场的一种产物,许多车型因为原厂的设计比较平庸,不能满足玩家的要求,因此就出现了改装行业的繁荣现象,气动避震悬挂的改装属于一种外观的姿态改装,以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣,一起来欣赏操控王者宝马3系 改装气动避震低姿态 真的很美
Car refitting is a product of the automotive aftermarket. Many models can't meet the requirements of the players because of the mediocre design of the original factory. Therefore, the refitting of the pneumatic shock absorber suspension is a kind of appearance posture modification, which causes strong resonance with the good feeling of the players close to the ground, strong visual impact and unconventional state, Let's enjoy the manipulation of the king BMW 3 series, refitting the aerodynamic shock absorber, and the low attitude is really beautiful
汽车避震是由弹簧和减震器共同组成的。
弹簧的作用是在行驶不平路面时消除震动,弹簧可以消除震动,那减震器干什么的?其实减震器是用来仰制弹簧吸震后反弹的震场和减缓路面冲击的能量。
如果你开过减振器已坏掉的车,你就可以体会汽车通过每一坑洞、起伏后余波荡漾的弹跳,而减振器正是用来抑制这种弹跳的。没有减振器将无法控制弹簧的反弹,汽车遇到崎岖的路面时将会产生严重的弹跳,过弯时也会因为弹簧上下的震荡而造成轮胎抓地力和循迹性的丧失。提到避震器就不得不提到另外一个名词叫“阻尼”,阻尼就是当我们以一固定的速度压缩或拉伸避震器、其所产生的阻力,所以,避震器的阻力可分为压缩和回弹两部分。而较硬的避震器产生的阻力会更大、回弹阻力自然也更大,能很好的抵挡弹簧压缩后再将轮胎压回地面的力、减缓反弹的冲击并保持车辆的平稳。
The function of spring is to eliminate vibration when driving on uneven road surface. Spring can eliminate vibration. What does shock absorber do? In fact, the shock absorber is used to invert the spring to absorb the rebound seismic field and reduce the energy of road impact.
If you drive a car with a broken shock absorber, you can experience the bouncing of the car after rolling through every hole, and the shock absorber is used to suppress this bounce. Without the shock absorber, the rebound of the spring can't be controlled. When the car meets the rough road, it will have a serious bounce. When crossing a bend, the tire's grip and tracking will be lost because of the vibration of the spring up and down. When it comes to shock absorbers, we have to mention another term called "damping". Damping is the resistance produced when we compress or stretch the shock absorbers at a fixed speed. Therefore, the resistance of shock absorbers can be divided into compression and rebound. The harder shock absorber will produce greater resistance and rebound resistance, which can resist the force of spring compression and then press the tire back to the ground, slow down the rebound impact and keep the vehicle stable.
