查看: 780|回复: 0
BMW Z4AIRBFT三段记忆手机app静音泵铝合金鱼雷罐气动避震
发表于 2020-9-19 14:58:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW z4airbft three segment memory phone app mute pump aluminum alloy torpedo tank pneumatic shock absorber
宝马Z4是宝马的一款轿跑车型,Z4 的设计是在 Z3 的基础上改进而来,长长的引擎盖,几乎落在后车轴上的非常贴背舒适的座椅。新车向上倾斜的尾部更具吸引力,加上两侧凹凸分明线条,使新车比 Z3 看起来更加霸气。
它的前辈宝马Z3roadster自从1995年(作为1996年型号)在邦德的新电影《黄金眼》中首次公众亮相后, 宝马Z4便一直成为众年青人追逐的对象。而时隔7年后,宝马公司再度推出完全修正的Z3换代产品,并且命名为Z4。
BMW Z4 is a sedan model of BMW. The design of Z4 is improved on the basis of Z3. It has a long hood and a very comfortable seat on the rear axle. The upward sloping tail of the new car is more attractive, and the concave convex lines on both sides make the new car look more aggressive than the Z3.
Since its predecessor, BMW z3roadster, made its debut in bond's new film "golden eye" in 1995 (as a 1996 model), BMW Z4 has always been the target of young people's pursuit. Seven years later, BMW launched a completely modified Z3 replacement product, named Z4.
改装就是一时冲动,头脑发热的一种状态,改装一旦开始会让你慢慢上瘾,无法自拔!因为看着自己心爱的车子越来越有魅力,不能停止对它的那种溺爱!看看宝马Z4改装气避震悬挂的魅力低姿态!
Refitting is a state of impulsive and feverish mind. Once you start refitting, you will become addicted and unable to extricate yourself! Because looking at their beloved car more and more attractive, can not stop the kind of doting on it! Take a look at the charming low attitude of BMW Z4 modified air suspension!
The working principle of pneumatic shock absorber is to change the height of the car by controlling the air pressure. It includes the toothed shock absorber, air pressure control system and electronic control system. At the auto show or the Party of car friends, we often see a lot of cars lying on the ground. Many people who have not seen it will think about how to drive this car. Don't worry. You can get it with one button
