查看: 546|回复: 0
陆风X7定制AIRBFT气动避震套装开工安装,保留了原车避震舒适性,提升了可玩性,...
发表于 2020-9-12 16:54:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
陆风X7定制AIRBFT气动避震套装开工安装,保留了原车避震舒适性,提升了可玩性,支持升降功能
Lufeng X7 customized airbft pneumatic shock absorber package started installation, retaining the original shock absorber comfort, improving the playability and supporting the lifting function
陆风X7是一款来自陆风品牌型号X7的汽车代号为E32,陆风X7于2015年8月6日正式上市,车身尺寸长度为4421mm,宽度为1911mm,高度为1631mm,其轴距为2660mm。
陆风X7中控台采取三种颜色组合的方案,而融入了多种设计风格,具有比较强的层次感,同时配备了一款10.2寸的液晶屏。我们在一些细节图片中发现,该车配备了发动机一键启动、雪地驾驶模式、运动模式、前雷达、电子手刹、自动空调、蓝牙电话以及导航系统
Lufeng X7 is a vehicle from Lufeng brand model X7, code named E32. Lufeng X7 was officially launched on August 6, 2015, with body size of 4421mm, width of 1911mm, height of 1631mm and wheelbase of 2660mm.
Lufeng X7 central console adopts three color combination scheme, and integrates a variety of design styles, with a strong sense of hierarchy, and is equipped with a 10.2 inch LCD screen. We found in some detailed pictures that the car is equipped with one button engine start, snow driving mode, sports mode, front radar, electronic handbrake, automatic air conditioning, Bluetooth phone and navigation system
