查看: 719|回复: 0
丰田凯美瑞改装案例|气动避震低姿态改装风格
发表于 2020-9-12 16:38:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Fengtian Camry refitting case | pneumatic shock absorber low attitude refitting style
凯美瑞是广汽丰田旗下的一款车型,37年来,历代凯美瑞都持续领先,赢得全球2000万车主的信赖。
外观方面,第八代凯美瑞造拥有豪华版、运动版双造型设计,这两种设计风格均源自丰田最新的“Keen Look”设计语言。豪华版车型采用巨幅的梯形横条格栅,车身呈流线姿态,腰线更低,延长的车顶后部增加了后排头部空间。
Camry is a model owned by GAC Toyota. Over the past 37 years, Camry has been leading the way and won the trust of 20 million car owners around the world.
In terms of appearance, the eighth generation Camry has luxury and sports dual design, both of which are derived from Toyota's latest "keen look" design language. The luxury model adopts a huge trapezoidal bar grille, with streamlined body and lower waistline. The extended rear part of the roof increases the rear row head space.
AIRBFT专用气囊:
Airbft special airbag:
