查看: 685|回复: 0
大众途观AIRBFT气动避震三段记忆版本手机APP遥控静音泵
发表于 2020-9-12 16:22:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen Tiguan airbft pneumatic shock absorber three segment memory mobile phone app remote control mute pump
大众途观是一款上海大众生产的汽车,于2010年3月26日公布价格。这款紧凑型SUV在2009年广州车展上首次与消费者见面。
全新途观在传承途观品牌“途有境而观无垠”品牌内涵的同时,
全新途观外观大气卓越、气宇昂扬。同时,全新增配的智趣方向盘换档拨片,让驾驶员无需松开方向盘即可便捷切换行驶档位,享受灵动自如的驾驶乐趣。 全新途观拥有同级领先的动感配置,驰骋灵动无可比拟。
Volkswagen Tiguan, a car made by Shanghai Volkswagen, announced its price on March 26, 2010. The compact SUV was first introduced to consumers at the 2009 Guangzhou auto show.
Brand new Tiguan inherits the brand connotation of Tiguan brand, namely, the concept of "the road has its boundary and the view is boundless",
The appearance of new Tiguan is excellent and high-profile. At the same time, the newly added Zhiqu steering wheel shift paddle allows the driver to easily switch gears without loosening the steering wheel, and enjoy the fun of flexible driving. New Tiguan has the same level of leading dynamic configuration, galloping nimble incomparable.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
