查看: 565|回复: 0
奔驰V260AIRBFT气动避震瞬间改善舒适性
发表于 2020-9-12 15:57:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mercedes Benz V260 airbft aerodynamic shock absorber improves comfort instantly
改装有不同的追求,轿车一般追求姿态美,越野车一般需要加高套件,商务车自然需要的就是舒适性。今天给大家分享的是奔驰V260提升舒适专用的空气悬挂套件,升降随心,舒适随心!
Refitting has different pursuits, cars generally pursue the beauty of posture, off-road vehicles generally need to increase the kit, and business vehicles naturally need comfort. Today, I'd like to share with you the special air suspension package of Mercedes Benz V260 for improving comfort!
汽车避震是由弹簧和减震器共同组成的。
