查看: 803|回复: 0
豪华、动感、成熟奥迪A6C6改装气动避震展现充满活力时尚的低趴姿态
发表于 2020-9-12 14:49:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Luxury, dynamic and mature Audi a6c6 refitted pneumatic shock absorber shows dynamic and fashionable low lying posture
奥迪A6L  C6在我看来是奥迪在国内最为成功的款车,它成功为奥迪打“官车”的标签,成熟稳重气。虽然现在的奥迪越来越年轻化,给人以多科技感,但是C6用扎实的做工,经典的外观,以及在速公路与同级别车比起来超乎寻常的驾驶体验终成一代经典
In my opinion, Audi A6L C6 is Audi's most successful car in China. It has successfully labeled Audi as "official car", mature and stable. Although Audi is getting younger and more technological, the C6 has become a classic with its solid workmanship, classic appearance and extraordinary driving experience compared with other cars of the same class on the highway
穷玩改装,富玩表,改装在国内属于起步阶段,没有非常规范的标准,每个人都是根据自己的喜好或者看着别人的改装车来把自己车进行改造,有钱的一步到位,没有钱的就慢慢攒,每个月改动一点,这样的人很多,也是中国改装市场的现状。今天我们来分享一辆改装案例,对于入门玩家空气避震的改装是首选,毕竟一低遮百丑!
Poor play refit, rich play watch, refit belongs to the initial stage in China, there is no very standard standard, everyone is according to their own preferences or looking at other people's modified cars to transform their own cars, the rich step in place, no money slowly save, change a little every month, such a lot of people, is also the status quo of China's refitting market. Today, let's share a case of refitting a car. The air shock absorbers for beginners are the first choice. After all, a low level covers hundreds of ugliness!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
