查看: 737|回复: 0
最强低姿态皇冠AIRBFT气动避震套件完美优质案例
发表于 2020-9-11 14:56:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
最强低姿态皇冠AIRBFT气动避震套件
The best low profile crown airbft pneumatic shock absorber
Crown is a large and medium-sized car brand of Toyota group. Toyota Crown was launched in Japan on January 1, 1955. There are more than the 13th generation models. The domestic crown engines are 2.5L, 3.0L and 4.3L. The first two engines are V6 cylinder 24 valve design, and the 4.3L engine is V-type eight cylinder. Dual VVT-i intelligent timing variable system of inlet and outlet valves is configured.
The intake efficiency, fuel economy and power performance of the engine are greatly improved, and the horsepower is more powerful. In terms of chassis, it adopts four-wheel fully independent suspension, which is very comfortable.
『气动减震器,能够轻易改变车身高度』李洋
