查看: 600|回复: 0
奥迪A4B8AIRBFT气动避震三段记忆版本氮气版本桶身 让姿态更加游刃有余
发表于 2020-9-11 14:16:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi a4b8airbft pneumatic shock absorber three segment memory version, nitrogen version barrel body makes posture more comfortable
奥迪A4(Audi A4)是由一汽大众公司制造并于2003年4月上市的一款B级车型。
作为率先引入长轴距和涡轮概念的车型,从B5到B8,A4L的销量一直经久不衰。新款A4舍弃了泪眼设计,增加了quattro四驱模式,外形更加时尚运动,动力和操控性更加出众。车型内饰做工精致,科技配置丰富,空间充裕,在B级车型中拥有较好的实用性。
B8是新A4的代号 B8是涡轮增压汽油直喷du发动机,燃烧性能zhi很好充分燃烧,dao燃料室的几何设计以及毫秒级精确计算注入汽油量的功能大大提高了其压缩比。
Audi A4 is a B-class model manufactured by FAW-VW and put into the market in April 2003.
As the first vehicle to introduce the concept of long wheelbase and turbine, A4L has been selling for a long time from B5 to B8. The new A4 abandons the tear eye design and adds Quattro four-wheel drive mode, which makes the appearance more fashionable and sporty, with more outstanding power and handling. The interior of the car is exquisite in workmanship, rich in scientific and technological configuration and abundant in space. It has good practicability in B-class models.
B8 is the code of new A4 and B8 is turbocharged gasoline direct injection Du engine. Its combustion performance is very good and full combustion. The geometric design of Dao fuel chamber and the function of accurate calculation of gasoline injection volume at millisecond level greatly improve its compression ratio. I happen to be an employee of FAW Volkswagen. I'm producing B8 right now. What do you don't know
