查看: 637|回复: 0
各大银幕专用车福特野马打造气压悬挂气动避震
发表于 2020-9-10 17:19:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ford Mustang, a special vehicle for screen, creates pneumatic suspension and shock absorption
1962年,福特研发了野马的第一辆概念车——Mustang I概念车。它是一部发动机中置的两座跑车。而野马的名称正是为了纪念二战中富有传奇色彩的美军P-51型Mustang战斗机。总的看来,野马的外形沉稳有余而动感不足,不过周身散发的那种稳重硬朗的气质,让人很容易感受得到。另外,野马给人一种极其质朴的感觉,如果驾驶野马牛仔装会比西装革履更加合适。
In 1962, Ford developed Mustang's first concept car, Mustang I. It's a two seater sports car with a central engine. The name of Mustang is to commemorate the legendary P-51 Mustang fighter in World War II. On the whole, the appearance of the wild horse is more stable than dynamic. However, it is easy to feel the steady and strong temperament of the whole body. In addition, Mustang gives people a very simple feeling, if driving Mustang jeans will be more suitable than suits.
野马是第一部或许也是唯一部有幸在纽约帝国大厦第86层观景台上停放的汽车。1965年下0月,福特的工程师将一辆飞966款野马活顶汽车拆成四部分,利用大厦的客梯将车送了上去。1966年野马销量达到了一百万辆的纪录。当前,已售出八百万辆之多,野马是连续17年最畅销的运动型轿车。
Mustang was the first, and perhaps only, car to park on the 86th floor of the Empire State Building in New York. In the second half of 1965, Ford's engineers broke down a 966 Mustang convertible top car into four parts and used the passenger elevator of the building to send it up. In 1966, Mustang sales reached a record of one million. Currently, as many as eight million vehicles have been sold, and Mustang is the best-selling sports car for 17 consecutive years.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
