查看: 673|回复: 0
简简单单便是真miniR56改装气动避震案例
发表于 2020-9-10 15:42:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
It is simply a case of refitting the real minir56 with pneumatic shock absorbers
在如今在这个时代之中,改装车被越来越多人所接受,吸纳。大多数改装厂对于自家产品推陈出新的速度也是越来越快。一时间对于改装件的选择可能会令你眼花缭乱。这台MINI或许是个不错的示范榜样,它身上没有过多吸引人的夸张部件,但是细节上却丝毫不含糊;他追求的就是那简单利落之感。
In today's era, refitted cars are accepted by more and more people. Most of the refitting factories are getting faster and faster to bring forth new products from the old. For a while, you may be dazzled by the choice of retrofits. Mini may be a good example, it does not have too many attractive exaggerated parts, but the details are unambiguous; what he pursues is the sense of simplicity and neatness.
