查看: 714|回复: 0
奔驰E300AIRBFT气动避震桶身完美改装
发表于 2020-9-9 14:24:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Perfect modification of Benz e300airbft pneumatic shock absorber barrel
奔驰的E300是来自奔驰家族的中坚力量,很多人一说到台车就会显得非常的激动。因为奔驰作为BBA中的龙头龙头老大,在车型上都是争议巨大的。前段时间奔驰的漏油门真的让奔驰承受了非常多的公关压力。而作为国内的比较顶尖的豪华车品牌,奔驰的产品力自然也不用说,那我们今天就好好说一下奔驰的E300。
Mercedes Benz E300 is the backbone of Mercedes Benz family. Many people will be very excited when they talk about the car. Because Mercedes Benz, as the leader of BBA, has a huge controversy in the model. A while ago, Mercedes Benz's oil leakage door really put Mercedes Benz under a lot of public relations pressure. As one of the top luxury car brands in China, Mercedes Benz's product strength is needless to say. Let's talk about Mercedes Benz's E300 today.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
