查看: 807|回复: 0
Kis stinger改装气动避震悬挂低趴风格魅力
发表于 2020-9-9 13:51:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Kis singer refitted pneumatic shock absorber suspension low lying style charm
起亚斯汀格(Stinger)是起亚旗下一款中大型车, 于2017年北美车展中正式亮相。 起亚斯汀格新车侧面采用掀背式线条设计,车辆后方的长灯延伸至中部,同时新车还配备有“花瓣式”铝合金轮圈 。尾部方面, 起亚 斯汀格采用了全新设计的LED尾灯组和双边共四出黑色椭圆形尾排,更能凸显运动属性。一起来欣赏起亚斯汀格改装AIRBFT气动避震悬挂的低趴魅力!
Steinger is a large and medium-sized car owned by Kia, which was officially unveiled at the North American auto show in 2017. Kia Stig's new car is designed with a hatchback line, and the rear lamp is extended to the center. The new car is equipped with petal type aluminum alloy rim. In terms of tail, kiastinger adopts a newly designed LED tail light group and a total of four black oval tail rows on both sides, which can highlight the sports attributes. Let's enjoy the low lying charm of modified airbft pneumatic suspension!
