查看: 670|回复: 0
福特蒙迪欧改装气动避震之后颜值立马上升一个段位
发表于 2020-9-8 15:48:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
After Ford Mondeo refitted pneumatic shock absorbers, her appearance rose by one rank immediately
福特蒙迪欧(Mondeo)是福特汽车公司在世界多个市场进行销售的一款中型轿车。 蒙迪欧“Mondeo”源于法语中“Monde”一词,是对优雅气质的描绘,是经典与尊贵的象征。“Mondeo”又有“Mondial”之意,即“全世界”,福特汽车借此表达出一种俯瞰世界的气度。
Mondeo is a medium-sized car sold by Ford Motor Company in many markets around the world.Mondeo, originated from the French word Monde, is a description of elegance and a symbol of classics and dignity. "Mondeo" also means "Mondial", which means "the whole world". Ford Motor expresses a kind of bearing of overlooking the world.
改装不分贵贱
玩的是过程
玩的是心态
张扬的个性
弘扬的文化
No distinction is made in refitting
Play is the process
It's about mentality
Publicity personality
Culture to promote
改装玩家: 一低遮百丑 气动配合好轮毂的尺寸和数据可以把车降到最低。静止时,把车降到最低趴在地上,帅。行驶时,根据路况任意调节喜欢的高度。
不改装 日常代步车主: 你可以认为他是为了方便任意上下马路牙子。很多女人说 好好的车干嘛要改 你也很美 干嘛要化妆
Refit player: one low cover hundred ugliness pneumatic matching wheel hub size and data can reduce the car to the minimum. When stationary, lower the car to the lowest, lying on the ground, handsome. When driving, adjust the height you like according to the road conditions.
Do not refit the daily car owner: you can think that he is to facilitate arbitrary up and down the road. A lot of women say that a good car needs to be changed, and you are beautiful. Why make up
一款好的气动避震品牌,那就是一个优质厂家,一个完整的质保售后服务体系, 产品的市场占有率,市场的口碑,市场的意见反馈! 负责任心的安装改装店,每一个细节的处理,交车前的排查漏气,松动异响,阻尼高度!自己改装前的内心实际需求,自己到底需要什么,想怎么玩,安装后是不是自己想要的效果,有没有使用过程中的方便.
