查看: 600|回复: 0
随心所“驭”高尔夫7GTI改装气动避震悬挂惊艳全场
发表于 2020-8-30 17:45:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Xinxinsuo golf 7gti refitted pneumatic suspension
不再听谁说,而是我要说
不再只去做,而是做成自己的信仰
不再骄傲,而把个性坚持成为骄傲
不再谈条件,而是创造条件去自由
高尔夫,集万千优越,只愿一路超越
去随心所“驭”,去实现自我
无论你是谁
只让你是你
高尔夫7是指高尔夫第7代产品。2013年12月10日,一汽-大众全新高尔夫7在广州正式上市。德国大众于1974年推出高尔夫1代产品,至今已经历7次换代了。高尔夫1代到7代是由老到新不断更新换代的一个车型。
No longer listen to who, but I want to say
No longer just do it, but make your own beliefs
No longer proud, but adhere to the personality to become proud
Instead of talking about conditions, we should create conditions for freedom
Golf, set thousands of superior, only willing to surpass all the way
Go to what you want to control and realize yourself
No matter who you are
Just let you be you
Golf 7 refers to the seventh generation of golf products. On December 10, 2013, FAW Volkswagen New Golf 7 was officially launched in Guangzhou. German Volkswagen launched the first generation of golf products in 1974, which has gone through seven generations. Golf generation 1 to 7 is a car model constantly updated from old to new.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
目前市场上主要分两种气动方式,机械式气动避震和电子式气动避震,不用明说,光听见电子这两个字,就知道技术含量比较高。价格上,比机械式气动避震要高,但是稳定性上没有机械式这么可靠。气动避震是一件比较精密的配件,和原厂避震相比完全是一个天一个地。气动避震上各有一个弹性橡胶气囊,气囊其实是一个密闭的压力缸,里面充满了惰性气体和油气混合物。腔体内的压力要比大气压高几倍甚至几十倍左右,再利用活塞杆的横截面积小于活塞的横截面积,来产生压力差,使活塞杆运动。因为气动避震是比较精密的部件,有气罐装置,不适合在颠簸路段进行剧烈的驾驶。容易导致慢性漏气,引起气压不稳定,气罐内的温度会升高,气动调节就会失去精准度。
At present, there are mainly two kinds of pneumatic shock absorbers in the market, mechanical pneumatic shock absorbers and electronic pneumatic shock absorbers. Needless to say, just hearing the word "electronic", you will know that the technical content is relatively high. The price is higher than the mechanical pneumatic shock absorber, but the stability is not as reliable as the mechanical type. Pneumatic shock absorber is a more precise accessory, compared with the original shock absorber, it is completely one day a place. There is an elastic rubber air bag on the pneumatic shock absorber. The air bag is actually a closed pressure cylinder filled with inert gas and oil-gas mixture. The pressure in the chamber is several times or even dozens of times higher than that of atmospheric pressure, and then the cross-sectional area of the piston rod is smaller than that of the piston to generate pressure difference and make the piston rod move. Because the pneumatic shock absorber is a more precise part and has an air tank device, it is not suitable for severe driving on bumpy roads. It is easy to cause chronic air leakage and unstable air pressure. The temperature in the air tank will rise, and the accuracy of pneumatic regulation will be lost.
