查看: 669|回复: 0
低调的奢华 高尔夫6改装气动避震能高能低 低姿态太美
发表于 2020-8-30 17:28:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Low key luxury golf 6 refitted pneumatic shock absorber with high energy and low posture
The so-called refitted vehicle, according to my personal understanding, is two refitting routes, performance and posture. Of course, there are many modified players for performance andIt's a good idea to think about both posture and posture, but it's very difficult to realize it. In the future, we'll take a special opportunity to discuss performance and postureThe problem of not having both. Today we're going to talk about the ultimate weapon of the attitude line modified vehicle, pneumatic shock absorption.
AIRBFT专用气囊:
Airbft special airbag:
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc. Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful.
