查看: 935|回复: 0
终“结者到来” 斯巴鲁翼豹STI8代-&11代翼豹STI改装气动避震
发表于 2020-8-29 15:00:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The final "coming of the knot" Subaru Impreza STI 8th-&11th Impreza STI modified pneumatic shock absorbers
斯巴鲁impreza翼豹以其卓越的性能在历届wrc世界拉力锦标赛中获得优异的成绩。量产车的设计研发与生产,也应用到了比赛中的成功经验,斯巴鲁翼豹wrx继承了纯正的赛车血统,06款第九代翼豹更是换装了2.5t发动机,并原车配备二次进气系统。
Subaru Impreza cheetah has achieved excellent results in the previous WRC World Rally Championships for its excellent performance. The design, R & D and production of mass production vehicles have also been applied to the successful experience in the competition. Subaru cheetah WRX inherits the pure racing pedigree, and the 06 9th generation cheetah is equipped with a 2.5t engine and the original car is equipped with a secondary air intake system.
