查看: 641|回复: 0
“凌风渡越”大众凌渡改装气动避震低趴魅力颜值直线飙升
发表于 2020-8-29 11:59:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Lingfengduyue" public lingdu refitted pneumatic shock absorber, low lying charm and beauty soaring
凌渡(Lamando)是上汽大众2014年8月在成都车展推出的一款紧凑型新车。
上汽大众将凌渡定义为“首款宽体轿跑车”,其基于MQB平台打造,搭载EA888 TSI、EA211 TSI发动机,采用湿式7速双离合变速器。
主打高端,属运动型紧凑车,定位于朗逸和帕萨特之间。
据介绍,“凌渡”二字取意于“凌风渡越”,英文名“Lamando”源于西班牙语中的“Mandar”,意为“指挥、管理、引领与启示”。
Lamando is a new compact car launched by SAIC Volkswagen in Chengdu auto show in August 2014.
SAIC Volkswagen defines lingdu as "the first wide body coupe", which is built on the MQB platform, equipped with EA888 TSI and ea211 TSI engines, and adopts a wet 7-speed dual clutch transmission.
It mainly focuses on high-end, and is a sports compact car, which is positioned between Langyi and Passat.
According to reports, the word "lingdu" takes the meaning of "lingfengdu", and the English name "lamando" comes from "mandar" in Spanish, meaning "command, management, guidance and Enlightenment".
低趴改装风格可谓是时下最流行的改装风格,纯粹的日本界大佬范儿VIP,衍生而出追求极致的hellaflush,包括来自美国西海岸的DUB,降低车身都是必不可少同时也是最重要的一步改装。正所谓一低遮百丑,低趴带来的美感无疑是不可代替的。爱美之心人皆有之,哪怕是定位年轻,造型运动的中级轿跑车,也渐渐丧失了对低趴姿态独特魅力的抵抗力,逐步加入到极致降低车身的队伍中来。
Low lying refitting style can be described as the most popular refitting style nowadays. The pure VIP of Japan is derived from hellaflush, which pursues perfection, including dub from the west coast of the United States. Lowering the body is essential and the most important step. It is the so-called low cover hundred ugliness, the beauty brought by low lying is undoubtedly irreplaceable. Everyone has a love for beauty. Even if it is a middle-class sedan car with a young positioning and sports style, it has gradually lost its resistance to the unique charm of low lying posture, and has gradually joined the team of extremely low body weight.
