查看: 700|回复: 0
别克GL8 AIRBFT气动避震三段记忆 手机蓝牙 静音泵 鱼雷罐
发表于 2020-8-29 11:46:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Buick GL8 airbft pneumatic shock absorber three segment memory phone Bluetooth mute pump torpedo tank
别克GL8作为顶级MPV的典范,以其豪华气派、动力强劲、宽敞舒适的优势实现批量出口,被东南亚媒体誉为“完美MPV”;更成为北京申奥、APEC会议等重大国际级外事活动的礼宾用车,比尔盖茨、马友友、帕瓦洛蒂都曾是其座上客。别克GL8家族由GL8 Avenir、GL8 ES及GL8商旅车组成三驾齐驱的产品布局。
Buick GL8, as a model of top-level MPV, realizes batch export with its luxury, powerful power, spacious and comfortable advantages, and is praised as the "perfect MPV" by Southeast Asian media. It has become a concierge car for Beijing Olympic bid, APEC conference and other major international foreign affairs activities. Bill Gates, yo Yo Ma and Pavarotti were all guests of Buick GL8. Buick GL8 family consists of GL8 Avenir, GL8 es and GL8 commercial vehicles, which is a three driving product layout.
汽车避震是由弹簧和减震器共同组成的。
