查看: 808|回复: 0
拾回一缕“芳华”奔驰E级改装气动避震 展现低趴诱人姿态
发表于 2020-8-29 10:30:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Retrieve a wisp of "Fanghua" Mercedes Benz E-class refitted pneumatic shock absorber to show attractive posture of low lying down
奔驰E级轿车是奔驰开发出的介于C级与S级之间的一款中大型高端商务轿车,跑车,旅行车,目前公认E级车的鼻祖是1947年的奔驰170,它是战后奔驰开发的第一批车型之一。
Benz E-class car is a medium and large-scale high-end business car, sports car and station wagon developed by Mercedes Benz between C-class and S-class. Currently, it is recognized that the originator of E-class car is Benz 170 in 1947, which is one of the first batch of models developed by Mercedes Benz after World War II.
穷玩改装,富玩表,改装在国内属于起步阶段,没有非常规范的标准,每个人都是根据自己的喜好或者看着别人的改装车来把自己车进行改造,有钱的一步到位,没有钱的就慢慢攒,每个月改动一点,这样的人很多,也是中国改装市场的现状。今天我们来分享一辆改装案例,对于入门玩家空气避震的改装是首选,毕竟一低遮百丑!
Poor play refit, rich play watch, refit belongs to the initial stage in China, there is no very standard standard, everyone is according to their own preferences or looking at other people's modified cars to transform their own cars, the rich step in place, no money slowly save, change a little every month, such a lot of people, is also the status quo of China's refitting market. Today, let's share a case of refitting a car. The air shock absorbers for beginners are the first choice. After all, a low level covers hundreds of ugliness!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
