查看: 742|回复: 0
AIRBFT铝合金鱼雷气罐高强度铝合金材料旋压成型,表面精抛细致处理,现货秒发
发表于 2020-8-29 09:55:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft aluminum alloy torpedo gas tank is made of high-strength aluminum alloy material by spinning. The surface is polished and treated carefully, and the product is delivered in seconds
『气动减震器,能够轻易改变车身高度』李洋
