查看: 767|回复: 0
爽爆了!!!经典高尔夫GTI气动避震改装案例欣赏
发表于 2020-8-28 14:59:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
爽爆了!!!经典高尔夫GTI气动避震改装案例欣赏It's amazing!!! Appreciation of Classic Golf GTI pneumatic shock absorber modification case
高尔夫GTI是大众汽车最经典的车型之一。高尔夫的定位是普通家用车,为了不使自己骨子里原本就非常运动设计的显得过于平庸,彰显动力性与操控性的版本GTI应运而生。第一代高尔夫GTI自1976年推出至今已经跨越了30余年的历史,到如今已经发展到第7代。
The Golf GTI is one of Volkswagen's most classic models. Golf is positioned as an ordinary family car. In order not to make the original very sporty design appear too mediocre, the version of GTI which shows the power and controllability came into being. The first generation of Golf GTI has spanned more than 30 years since it was launched in 1976, and now it has developed to the seventh generation.
2009年2月12日上映的《飞车惊魂》讲述了车技娴熟的急救站司机本应聘到德国一个大型公司做总经理夫人克里斯娜的专职。然而上班的第一天,他就陷入一场精心策划的绑架勒款案,目的是以克里斯娜的性命为代价索要500万欧元。本和克里斯娜驾驶的高尔夫GTI汽车是被改造过的,由犯罪团伙在远端卫星定位遥控,此高尔夫GTI汽车车门被全部封闭,如果本和克里斯娜不配合,装在汽车底部的炸弹会随时引爆。此时,犯罪团伙还向警察报案说是克里斯娜遭绑架,绑匪就是本。面对突如其来的变故,为了脱离危险,洗脱罪名,本不得不使出浑身解术与绑匪周旋,一场生死较量拉开序幕。
On February 12, 2009, the movie "the thrill of flying car" tells the story of the skillful driver of emergency station who was employed as the full-time wife of general manager of a large German company. However, on his first day at work, he was involved in a well-designed kidnapping and extorting 5 million euros at the cost of crisna's life. The Golf GTI car driven by Ben and Krishna has been transformed. It is remotely controlled by a criminal gang through remote satellite positioning. The door of the Golf GTI car is completely closed. If Ben and Krishna do not cooperate, the bomb installed at the bottom of the car will detonate at any time. At this time, the Criminal Gang also reported to the police that it was Krishna who was kidnapped and Ben was the kidnapper. In the face of sudden changes, in order to get out of danger and get rid of the crime, Ben had to use the whole body solution to deal with the kidnappers, and a life and death contest began.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款,
听起来非常方便,气动避震到底是什么原理呢?
Air shock absorber is the most expensive one among the topics,
