查看: 957|回复: 0
紧跟低趴潮流,本田思铂睿改装气动避震
发表于 2020-8-28 14:37:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
紧跟低趴潮流,本田思铂睿改装气动避震
Keep up with the trend of low-lying, Honda spiro refits pneumatic shock absorber
思铂睿(Spirior)开创了“高端运动”设计理念,搭载多项世界高端技术,思铂睿中的S意为Sporty Premium Sedan,即高端运动型轿车。R意为Research and Development,即研究开发中。本田高端运动车思铂睿与讴歌TSX和欧版雅阁源自相同的基础平台。
Spirior has created a "high-end sports" design concept, equipped with a number of high-end technologies in the world. S means sporty premium sedan, that is, high-end sports cars. R means research and development. Honda's high-end sports car sibluri is derived from the same basic platform as acura tsx and European accord.
AIRBFT专用气囊:
Airbft special airbag:
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。
通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc.
Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful.
