查看: 660|回复: 0
“四驱绅士” 新款大众CC改装气动避震低趴经典案例
发表于 2020-8-27 17:31:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Classic case of refitting the new VW cc with aerodynamic shock absorber
一汽-大众CC是一汽-大众旗下一款运动型的轿车。大众CC将轿车的稳定性与跑车的灵敏度结合。它采用4门无框设计,内饰具有运动风格,延续了大众汽车商务轿车系列车型的风格,真皮跑车座椅以及真皮智能运动型方向盘。
FAW Volkswagen CC is a sports car owned by FAW Volkswagen. Volkswagen CC combines the stability of a car with the sensitivity of a sports car. It has a 4-door frameless design and sporty interior, continuing the style of the Volkswagen business sedan series, leather sports seats and leather intelligent sports steering wheel.
大众CC被很多人认为是大众品牌有史以来外观最好看的一款车,在我眼里他就好像一位风度翩翩的绅士,有外在,也有内涵。今天我们来看一看这台大众CC改装气动避震的低趴经典案例。
Volkswagen CC is considered by many people to be the best looking car in the history of VW brand. In my eyes, it is like a gentleman with elegant demeanor. It has both exterior and connotation. Today, let's take a look at this classic case of Volkswagen CC refitting pneumatic shock absorber.
