查看: 731|回复: 0
低趴气动大王范,奔驰C级改装气动避震系统案例
发表于 2020-8-27 16:55:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A case of refitting the C-class pneumatic shock absorber system of Mercedes Benz
现在大多数车主,买车的时候除了喜欢看外观、内饰、配置、动力和口碑等等之外,也会考虑该车有没有改装的潜力。随着汽车个性化、舒适性的需求逐渐提高,汽车已不再是简单的交通工具,而是一个能够为人们带来乐趣舒适的玩伴。改装气动避震低姿态对很多年轻的车友来说,完美的姿态有很大的吸引力,一起来欣赏奔驰C级的魅力低姿态风格!
At present, most car owners, in addition to looking at the appearance, interior, configuration, power and reputation, will also consider whether the car has the potential to be modified. With the increasing demand for personalized and comfortable cars, the car is no longer a simple means of transportation, but a playmate who can bring fun and comfort to people. For many young riders, the perfect posture has great attraction. Let's enjoy the charm of Mercedes Benz C-class with low attitude!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
