查看: 779|回复: 0
为奢华代言 宾利欧陆GT改装AIRBFT气动避震悬挂尊贵之选
发表于 2020-8-26 17:06:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
For luxury endorsement Bentley Continental GT refitting airbft pneumatic suspension
宾利欧陆GT是一款豪华运动轿车,传乘了宾利完美无瑕的贵族轿跑车血统。做工精湛而考究,每一个细枝末节都散发着纯正宾利不可言传的阳刚之气——宾利的DNA:那就是英式传统、经典设计、传奇色彩和含蓄自信的绅士风范。
气质高贵而脱俗;材质精选而完美。欧陆GT 彰显着宾利鲜明的设计风格:霸气的车头、网状的电镀格栅、四个圆形车灯、大轮毂和强悍的车轮拱板,这些都象征着活力与激情。值得一提的是欧陆GT的仪表盘面板上镶有一款别致的小钟。这是由以精确著称于世的飞行表百年灵特别为宾利欧陆GT设计的。
Bentley Continental GT is a luxury sports car, passing on Bentley's flawless noble sedan pedigree. The craftsmanship is exquisite and exquisite. Every detail exudes pure Bentley's unspeakable masculinity -- Bentley's DNA: that is, British tradition, classic design, legendary color and implicit and confident gentleman style.
The temperament is noble and refined; the material is selected and perfect. Continental GT shows Bentley's distinctive design style: aggressive front, mesh plated grille, four round lights, big wheel hub and strong wheel arch plate, all of which symbolize vitality and passion. It is worth mentioning that the dashboard panel of Continental GT is inlaid with a chic small clock. This is designed by Breitling, the world's most accurate flight watch, specially designed for the Bentley Continental GT.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
