查看: 722|回复: 0
分享给本田的死忠们!八代思域经典改装气动避震案例
发表于 2020-8-26 16:19:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Share with Honda's diehards! Eight generations of civic classic retrofit aerodynamic shock absorbers
在改装了气动避震后,更加凸显时尚炫酷范儿,在正常行驶时可以根据路面状况的不同自由选择爱车的高度,朋友聚会时一趴到底,相信会为你博得更多关注,在遇到烂路时,提高车身高度,增强车身的通过性,采用的是空气悬挂系统,是目前生产气动避震器历史最悠久的厂家,质量与稳定性更加值得你信赖
After refitting the pneumatic shock absorber, it is more fashionable and cool. When driving normally, you can freely choose the height of your car according to the different road conditions. If you lie down to the bottom during the Party of friends, I believe it will attract more attention for you. In case of bad road, improve the height of the body and enhance the trafficability of the body. The use of the air suspension system is the history of the production of pneumatic shock absorbers The oldest manufacturer, quality and stability more worthy of your trust
