查看: 551|回复: 0
引领低趴潮流大众凌度改装AIRBFT气动避震彻底爱上低姿态
发表于 2020-8-25 17:38:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Leading the trend of low lying down, Volkswagen refitted airbft pneumatic shock absorber, fell in love with low attitude
据介绍,“凌渡”二字取意于“凌风渡越”,英文名“Lamando”源于西班牙语中的“Mandar”,意为“指挥、管理、引领与启示”。
According to reports, the word "lingdu" takes the meaning of "lingfengdu", and the English name "lamando" comes from "mandar" in Spanish, meaning "command, management, guidance and Enlightenment".
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
