查看: 621|回复: 0
完美蜕变低趴魅力 奔驰W205改装AIRBFT气动避震
发表于 2020-8-25 17:26:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Perfect transformation low lying charm Mercedes Benz w205 refitted with airbft pneumatic shock absorber
奔驰C w205改装AIRBFT气动避震,如果仅仅将奔驰C作为代步工具的话会觉得索然无味,在这个追求个性,享受驾车的愉悦的年代,改装气动避震,才是奔驰C应有的生活态度。
If Benz C w205 is refitted with airbft pneumatic shock absorbers, it will be boring if only using Benz C as a walking tool. In this era of pursuing individuality and enjoying driving pleasure, refitting aerodynamic shock absorber is the proper life attitude of Benz C.
AIRBFT专用气囊:
Airbft special airbag:
