查看: 787|回复: 0
彻底无语!史上最强悍的气动避震改装低趴案例
发表于 2020-8-23 17:30:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Completely speechless! The most powerful pneumatic shock absorber refitting low lying case in history
低趴改装风格可谓是时下最流行的改装风格,纯粹的日本界大佬范儿VIP,衍生而出追求极致的hellaflush,包括来自美国西海岸的DUB,降低车身都是必不可少同时也是最重要的一步改装。正所谓一低遮百丑,低趴带来的美感无疑是不可代替的。爱美之心人皆有之,哪怕是定位年轻,造型运动的中级轿跑车,也渐渐丧失了对低趴姿态独特魅力的抵抗力,逐步加入到极致降低车身的队伍中来。
Low lying refitting style can be described as the most popular refitting style nowadays. The pure VIP of Japan is derived from hellaflush, which pursues perfection, including dub from the west coast of the United States. Lowering the body is essential and the most important step. It is the so-called low cover hundred ugliness, the beauty brought by low lying is undoubtedly irreplaceable. Everyone has a love for beauty. Even if it is a middle-class sedan car with a young positioning and sports style, it has gradually lost its resistance to the unique charm of low lying posture, and has gradually joined the team of extremely low body weight.
