查看: 615|回复: 0
老款甲壳虫改装气动避震案例,更添时尚帅气
发表于 2020-8-23 16:43:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The old beetle refits the pneumatic shock absorber case, adds the fashion to be handsome
甲壳虫成就了大众品牌的发展,它的热销也催生了独特的甲壳虫改装文化。   经典外观车型,再到车型的内外兼修, 都呈现出了不同的性格,延续着自己不同的使命。 尤其是对于造型设计对老款甲壳虫来说,外观改装都是非常适合,低矮的车顶线条配合掀背式的尾部造型体现出了前所未有的男人味儿,为后续的改装提供了不少空间。下面,为大家盘点几个甲壳虫经典改装案例,有点萌萌哒!
Beetle has achieved the development of popular brands, and its hot sale also gave birth to a unique beetle refitting culture. Classic appearance models, and then to the internal and external repair of models, all present different personalities and continue their different missions. Especially for the styling design, for the old beetle, the appearance modification is very suitable. The low roof line and hatchback tail shape reflect the unprecedented masculine taste, which provides a lot of space for subsequent modification. Now, for you to take stock of several beetle classic modification cases, a little cute!
