查看: 606|回复: 0
最具动感的大众尚酷气动避震改装作业
发表于 2020-8-22 17:33:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
最具动感的大众尚酷气动避震改装作业
The most dynamic Volkswagen Shangku pneumatic shock absorber refitting operation
谈到气动避震的改装,首先想到的就是尚酷,因为个人的喜好,英文名称Scirocco,拥有前卫动感的设计,被誉为“大众汽车有史以来最具动感”的双门轿跑车。这么出色的外观设计风格,给气动避震的改装做了一个很好的基础,这套气动避震是由台湾SF绞牙避震升级而来,采用高压橡胶气囊来替代螺旋弹簧,柔韧性更加出色!
When it comes to the refitting of pneumatic shock absorbers, the first thing I think of is Shangku. Because of my personal preference, Scirocco has the avant-garde dynamic design and is known as "the most dynamic coupe in the history of Volkswagen". Such an excellent appearance design style has laid a good foundation for the modification of pneumatic shock absorbers. This set of pneumatic shock absorbers is upgraded from Taiwan SF twisted teeth shock absorbers. The high-pressure rubber air bag is used to replace the spiral spring, so the flexibility is better!
