查看: 808|回复: 0
奔驰威霆商务车简单改装气动避震 洗尽尘世的繁杂
发表于 2020-8-22 17:25:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Simple refitting of Mercedes Benz Weiting commercial vehicle with pneumatic shock absorber
气动避震是安装在汽车上面的一种空气悬挂减震器,是用橡胶空气减震器代替原车的弹簧减震器,使车身高度自由升降,越野路面车身可以升高,高速上车身可以降低,安装了气动避震的车子通过性很好,减震性能和舒适性都比原车的好很多
Pneumatic shock absorber is a kind of air suspension shock absorber installed on the car. Rubber air shock absorber is used to replace the spring shock absorber of the original car, so that the height of the body can be raised freely on the off-road Road, and the body can be lowered at high speed. The vehicle equipped with pneumatic shock absorber has good trafficability, and its shock absorption performance and comfort are much better than those of the original vehicle
