查看: 672|回复: 0
奔驰E级AIRBFT气动避震施工后备箱简单造型设计
发表于 2020-8-22 16:43:09 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Simple modeling design of construction trunk of Mercedes Benz E-class airbft pneumatic shock absorber
奔驰E级轿车是奔驰开发出的介于C级与S级之间的一款中大型高端商务轿车,跑车,旅行车,目前公认E级车的鼻祖是1947年的奔驰170,它是战后奔驰开发的第一批车型之一。
Benz E-class car is a medium and large-scale high-end business car, sports car and station wagon developed by Mercedes Benz between C-class and S-class. Currently, it is recognized that the originator of E-class car is Benz 170 in 1947, which is one of the first batch of models developed by Mercedes Benz after World War II.
