查看: 666|回复: 0
小可爱甲壳虫改装气动避震案例,更添时尚帅气
发表于 2020-8-21 17:44:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Small cute beetle refitted pneumatic shock absorber case, more fashionable and handsome
如果说低趴风格改装已成风,大家对此已经见怪不怪的话,那么相信接下来的这台本田奥德赛一定会非常引人眼球,继气动悬挂成为大家改装的主流之后,极端的“恐高症”患者们都开始往更加极端的方式去改装,低趴的姿态与硕大尺寸的轮毂完全不能满足他们的胃口,所以视觉效果十分夸张的宽体车身就成为了他们的改装方向。If it is said that low lying style refitting has become a fashion, and everyone has seen it all the time, I believe that the next Honda Odyssey will be very eye-catching. After pneumatic suspension has become the mainstream of everyone's modification, the extreme "acrophobia" patients begin to modify in more extreme ways. The low lying posture and large size wheel hub can not meet their needs Appetite, so the visual effect is very exaggerated wide body body has become the direction of their refitting.
