查看: 829|回复: 0
太美了,斯巴鲁森林人也来改装气动避震低趴诱惑挡不住
发表于 2020-8-21 17:34:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
It's so beautiful. The Subaru forest people have also come to refit the pneumatic shock absorber. The temptation of low lying can't be stopped
斯巴鲁森林人(Forester)最早于1997年2月份首次面世。森林人汇集了多功能车和客车的特点,如果引用现代的概念,就是一款“交叉”车型。森林人的底盘借鉴了 1993年的斯巴鲁力狮,移植到森林人的身上,这款经典的底盘被缩小了轴距,提高了离地间隙,但是全时四驱和水平对置发动机没有改变。因此森林人不但拥有在恶劣路况条件下的卓越性能以及多用运动车(SUV)所要求的较高的驾驶位置的同时,它还为车手提供令人愉悦的舒适驾驶。
The first appearance of the Subaru Forester was in February 1997. Forest people have collected the characteristics of multi-functional vehicles and buses. If modern concepts are used, it is a "cross" model. Forestman's chassis borrowed from Subaru lion in 1993 and transplanted to forestman. This classic chassis has been reduced wheelbase and improved ground clearance, but the full-time 4WD and horizontal opposed engine have not changed. Therefore, forestman not only has excellent performance in bad road conditions and the higher driving position required by SUV, but also provides drivers with pleasant and comfortable driving.
低趴改装风格可谓是时下最流行的改装风格,纯粹的日本界大佬范儿VIP,衍生而出追求极致的hellaflush,包括来自美国西海岸的DUB,降低车身都是必不可少同时也是最重要的一步改装。正所谓一低遮百丑,低趴带来的美感无疑是不可代替的。爱美之心人皆有之,哪怕是定位年轻,造型运动的中级轿跑车,也渐渐丧失了对低趴姿态独特魅力的抵抗力,逐步加入到极致降低车身的队伍中来。
Low lying refitting style can be described as the most popular refitting style nowadays. The pure VIP of Japan is derived from hellaflush, which pursues perfection, including dub from the west coast of the United States. Lowering the body is essential and the most important step. It is the so-called low cover hundred ugliness, the beauty brought by low lying is undoubtedly irreplaceable. Everyone has a love for beauty. Even if it is a middle-class sedan car with a young positioning and sports style, it has gradually lost its resistance to the unique charm of low lying posture, and has gradually joined the team of extremely low body weight.
