查看: 721|回复: 0
低姿态美到爆!福特野马改装气动避震
发表于 2020-8-21 17:18:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
低姿态美到爆!福特野马改装气动避震
Low profile, beautiful to explode! Ford Mustang refitted pneumatic shock absorber
喜欢改装的朋友可以看过来,AIRBFT气动避震每天分享国内各种车型精彩的改装案例,供玩家们欣赏和借鉴,为中国的改装事业献出自己的一点点贡献,今天我们来欣赏福特野马改装AIRBFT气动避震悬挂,开启低趴之路的魅力!
For those who like to refit, shares the wonderful refitting cases of various domestic models every day for players to appreciate and learn from, and to contribute a little bit to China's refitting cause. Today, we'd like to appreciate the charm of Ford Mustang refitting airbft pneumatic shock absorber suspension to open the road of low lying down!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
