查看: 671|回复: 0
完美低趴分享丰田凯美瑞改装气动避震改善视觉效果
发表于 2020-8-21 17:07:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Perfect low prone to share Toyota Camry refitted pneumatic shock absorber to improve visual effect
近几年气动避震的改装在国内可谓是迅速的蔓延开来,很多玩家第一步就是要改装一套气动避震,因为“百改降为先”嘛,后期很多的改装都是以气动避震的低趴姿态为基础来一点点的完善的!
In recent years, the refitting of pneumatic shock absorbers has spread rapidly in China. The first step for many players is to refit a set of pneumatic shock absorbers. Because "the first step is to change everything to the first", many of the later modifications are based on the low prone posture of pneumatic shock absorbers!
AIRBFT专用气囊:
Airbft special airbag:
