查看: 817|回复: 0
还好没有错过你阿特兹改装气动避震悬挂完美低趴姿态分享
发表于 2020-8-21 16:09:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Fortunately, I didn't miss you, ATZ modified pneumatic suspension, perfect low lying posture sharing
玩改装无非就是两种路线,一种是走性能路线,就是让车子更快,更稳;另一种就是走外观姿态路线,气动避震改装应该是属于后者,因为降低车身的视觉效果是非常的突出的,再搭配一套数据合适的轮毂!简单而且效果突出,就像下面的这台阿特兹!
There are only two routes to play with refitting. One is to take the performance route, which is to make the car faster and more stable; the other is to take the appearance and posture route. Pneumatic shock absorber refitting should belong to the latter, because the visual effect of reducing the body is very prominent, and then a set of wheels with appropriate data will be used! Simple and effective, just like the ATZ below!
Pneumatic shock absorber is a more precise part. Different from the original shock absorber, there is an elastic rubber air bag on the pneumatic shock absorber. The working principle of the elastic rubber air bag is to fill the sealed pressure cylinder with inert gas or oil-gas mixture, so that the pressure in the chamber is several times or dozens of times higher than atmospheric pressure. The cross-sectional area of piston rod is smaller than that of piston And the resulting pressure difference to achieve the movement of the piston rod. Pneumatic shock absorbers are not suitable for driving on various complicated road conditions. Long term driving on bumpy roads will lead to chronic air leakage, unstable air pressure, temperature rise in the air tank, and eventually lose the accuracy of pneumatic adjustment.
