查看: 829|回复: 0
宝马mini改装AIRBFT气动避震玩低趴姿态 效果更加迷人
发表于 2020-8-20 16:18:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW Mini modified airbft pneumatic shock absorber for low prone posture
不知从何时开始,HellaFlush这股风潮慢慢风行于全中国改装圈子,在国内由开始把车身尽降做法到后来讲究大倾角,轮毂与轮眉齐平,气动等等等等做法着实令不少玩家着迷。
I don't know when it started. Hella flush has gradually become popular in China's refitting circle. In China, it started to lower the car body to pay attention to the large inclination angle, the wheel hub and wheel brow are flush, and so on. Many players are fascinated by this trend.
Comfort and handling have always been the two core standards to measure the performance of a car. However, in the first hundred years of automobile development, the two have always been enemies in the eyes of designers, and it is difficult to give consideration to each other. In this regard, many automobile design masters have developed various technologies to solve this problem, but the most significant milestone is the advent of air suspension technology! Compared with the coil spring suspension used in ordinary vehicles, the absolute advantage of air suspension is obvious. First of all, unlike the spring, air has only one fixed stiffness. Through the adjustment of air valve and air pump, its elastic coefficient can be changed. Accordingly, the soft and hard degree of the shock absorber can also be adjusted, so that the comfort is greatly improved. Secondly, the length and stroke of the air spring can also be controlled by the amount of compressed air. So we see a chassis that can be raised and lowered.
So, what is pneumatic shock absorbers? The working principle of pneumatic shock absorbers is to change the height of the car by controlling the air pressure, so as to improve the trafficability of the car. It includes elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system, which will be more comfortable. At the auto show or the Party of car friends, we often see a lot of cars lying on the ground. Many people who have not seen it will think how the car can be so low! In recent years, car riders often talk about "one low cover three ugliness", and Hella flush is a modification style which deduces this sentence to the extreme. In hellaflush style refitted cars, in addition to paying great attention to the wheel hub J value, et value and exaggerated camper parameters, the remaining important problem is to reduce the body. So many friends will directly choose the hinge suspension, because it can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is welcomed by many riders with one stroke. However, for the ultimate players of Hella flush, the toothed shock absorbers have been unable to meet their "low" demand, so pneumatic shock absorbers have won the hearts of these ultimate players by virtue of its flexible ability.
